I've now been using PI 10 and find that one of my favorites - the lasso tool has gotten "jittery". With previous versions of the program, you could be very precise about your outline of an object. With the new version, the lasso starts skippin all over the place and making a ragged line. Is there a setting I'm missing?
Terry
What did they do to the lasso tool?
VT Photog
Haven't noticed any problems.
But, I don't understand your "jiggly problem" to the fullest.
The image below shows my basic settings in the "options" box.
Is "anti-aliasing" ticked in your case?
In the image used, the lasso outline is jiggly, but that is due to the subject matter and, perhaps, my control of the mouse. The "soft edge" is set to "0" to eliminate any softness.
Have you tried the "smart lasso" control? The setting of "Detection Scope" may also have a bearing.
Just offering suggestions to get a better understanding of your problem.
thecoalman
tdew
Brian, BobM & VT Photog,
THANK YOU!
My problem was the "smart lasso". When it was checked, it was impossible to do the precise selection that I was used to doing in other versions of the program. I knew the smart lasso was one of the improvements, and was looking forward to testing it out, but didn't realize that I'd have to turn it OFF right from the start.
I can see that there are many more tricks to learn with the new tools.
Thanks again.
Terry
THANK YOU!
Thanks again.
Terry
