hey,
how do you single someone out like put a circle or a box around someone.
i am making a gamefilm for football and i need to single myself out. thanks
I need help with an effect
I've found the easiest way to do this in VS is to use the Light video filter. You have to adjust the parameters to get it where you want it. If you want it to move you'll have to use the keyframes.
Also, check here under Free Stuff for Use with Ulead Products and Third Party Commercial Software for Intervideo-Ulead products for more sophisticated apps to do this.
Jeff
Dentler's Dog Training, LLC
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Place circle on a subject
Or you could go the the "object" library via" decoration" and select the red circle then drag it into the overlay track.You can then resize and re position it to where you want it in a still image.A still can be saved from your video of any frame you select regards Ken
That's a good one, Ken.
Jeff
