Is posible to split cip in "Select source and Import" after edit clip in edit room?
I'm using MF6 Plus for some video edting and making dvd.
I'm done editing my video in editroom but there only 1 clip in "Select source and import" windows and there only 1 clip in menu heading.
I want saveral clip in menu home page so I must split clip in "Select source and import" right? but split clip button is gray out.
Can I split clip after edit clip in edit room? (My clip had symbol in lower left look like razor blade.)
Or there are other way to make several clip in menu home page without split clip in "Select source and import" windows?
Is possible to split clip after edit clip in edit room?
Did you mean submenus linked to a certain frame of your video clips? You don¡¦t have to split the clips in the ¡§Add media¡¨ window in order to create chapters for your menu. Submenus contain chapters and these chapters are like bookmarks to your video clips. You can create bookmarks or chapters automatically or at fix interval using ¡§Add/Edit Chapter¡¨ from the ¡§Select source and import (Step: 1/3)¡¨ window. Using ¡§Auto Add Chapters¡¨, your video must be at least one minute long or have scene change information. You can also manually create chapters by dragging the Jog Slider to look for the first frame of a chapter and click ¡§Add Chapter¡¨. You can create up to 99 chapters for a video clip.
