Photo Explorer 8.0 slideshow
hawkette64
Just created a slideshow and burned to a computer cd. The picture quality is excellent, first program I used with such quality results. However the pictures are not in the same order as when I created the slideshow. Any suggestions?
hawkette64
htchien
If you import the pictures by using the Camera Wizard of PhotoExplorer, you can check an Renumber images to ensure every file name is unique option to solve this problem.
If you are using the Digital Camera Wizard of Windows XP to import the pictures, it will have an option to let Windows XP rename them by date automatically.
Hope this helps.
H.T.
Hope this helps.
H.T.
hawkette64
Thanks for the reply. I had the pics on the computer from a Fuji camera and program. I will look at the options you mentioned. I'm not sure now that was the problem. I went thru and renamed the dup names and saved the slideshow again. Will try to burn another cd soon and see what happens. Thanks again.
hawkette64
