Should you use TFF for HDV to DVD burns?
jmone
motherboard: ASUS P8Z77-VPro
processor: i7 3770K OC
Video Card: ASUS GTX660 OC
sound_card: FiiO E10
Hard_Drive_Capacity: 60TB
Post by jmone »
I keep most of my video in its native form on an HTPC but I take it that when I need to Burn a DVD from HDV footage that the "best" template settings would be "Top Field First" given that is the order in HDV but I notice that the included DVD Templates all use BFF.
The settings I have created for my HDV to DVD Disk Template is:
24 bits, 720 x 576, 25 fps, Upper Field First, (DVD-PAL), 16:9
Audio data rate: 384 kbps
Any advice is welcome! (like should I just output frame based?)
Nathan
EDIT: I am using a PAL Canon DV20 that records to tape using the 1440/1080i/50Hz HDV Standard. Now I've also used the cameras internal 25P setting for much of the shooting so I have a combo of 50i and 25p based content inside the HDV 1440/1080i/50Hz stream.
Note: cross post from DVINFO.NET
If your source file is upper field first then your output file should be upper field first.
If your source file is lower field first then your output file should be lower field first.
etech6355
Post by etech6355 »
I've heard it's not good practice to mix HDV & DV on the same tape.
I guess you haven't had any problems.
jmone
Post by jmone »
sjj1805 wrote:If your source file is upper field first then your output file should be upper field first.
Thanks for the confirmation and why I created the DVD Template for UFF!
Nathan
jmone
Post by jmone »
etech6355 wrote:I've heard it's not good practice to mix HDV & DV on the same tape.
So have I but I'm only recording HDV on the tape (just some is 50i and some is 25p)...
