smart remove is disabled
Helge
Post by Helge »
I wanted to remove some persons from an image with smart remove. (PI11) I have two images from the scene, both scanned from slides. My problem is that the menu entry "smartremove" is disabled.
Is this because I have only two images? As far as I understand the manual it should work with two images also if I use manual mode. Or is it a problem with the file type? I tried with psd, jpg and tiff. Or is it because my files dont contain exif information?
According the built in help file in PhotoImpact 12:
1. Open at least two EXIF images of the same image size, aperture, shutter speed, and ISO values.
Helge
Post by Helge »
Thanks Steve,
I had read this also in the manual, but I didn't take it so verbose and serious. I understand that this are preconditions for good results but I thought it to be the responsibility of the user - not that PI would verify it.
According to exif spec both jpg and tiff are exif formats (even if the dont contain exif information).
Since I scanned the images (coolscan iv, silverfast) it's very unlikely they have even the same size. It's much more likely the size varies a few pixels. (Also this would be the easiest one factor to adjust.)
While I could use an exif tool to fake the information I will simply use an other technik.
I hope Ulead will make this functionality easier to use in future versions.
arhebabill39
need more help
Post by arhebabill39 »
Hi all and Steve;
I did all the things to do a smart remove and it does not remove the objects or items I colored to remove all I get is an other picture of the same pic I am working on. here is what I did I open PI and opened a jpeg pic and duplicated it and went to smart remove and folowed the info and it does not remove anything can you help on how to get this to work?
Bill
Bill,
I think when you duplicated your original image inside of PI-12, it stripped all the EXIF data. Thus PI thinks you don't have at least 2 images having the same EXIF data, and will not activate the Smart Remove tool.
Try taking 2 pictures without changing the camera's settings, and see if that activates the Smart Remove tool.
Helge
Post by Helge »
Hi Bill,
it will generally not be possible to remove anything if you duplicated the image. Why? Because the images need to be different.
Suppose you want to take a foto of a historical building. Unfortunatly peaople are walking before it. So if you are not a so important fotographer that the police will hold people off while you take your snapshot you have only the chance to take multiple fotos. With little luck parts covered from unwanted people on one picture are not covered on an other. So you can overlay the images and cut the persons you do not want. You can do this with nearly any image edding application, but usually the images differ slighly in lighting / color, (because e.g. of moving clouds), so you have to adjust hue, brightness ... Here is where PI helps, automating this job.
nmehta
SmartRemove Tutorial
Post by nmehta »
Hi Helge,
We have created 3 video tutorials on SmartRemove which might help you:
http://takeoneflix.com/ulead-photoimpac ... e-objects/
http://takeoneflix.com/ulead-photoimpac ... g-objects/
while these may not exactly solve your problem, I'm sure they will guide you in the correct direction.
Edit by sjj1805 - Web Board Administrator 26 Feb 2009.
When this post was created the video tutorials mentioned were all free.
That has now changed and members are advised that they have to be purchased. I must point out that these links are only provided for the purpose of convenience to our members. Neither Corel, the Forum Management or myself endorse any of the products listed and I/We have no associations with the vendors of any software listed below. I/We do not guarantee the quality of any of these products or their compatibility with the Corel products they are designed to work with. I/We will not enter into any negotiations between Members and the Company providing these tutorials.
Neel Mehta
[size=117][color=red]Many useful VideoStudio and PhotoImpact tutorials can be found at
[/color][url]http://seeitdoit.tv[/url][/size]
Helge
Post by Helge »
Thanks a lot for all hints!
Of course I have circumvented the problem meanwhile. You can see the resulting image on my webside here:
http://www.hans-helge-mueller.de/slides/1142410.htm
I have put small resolution versions of the original images also here:
http://www.hans-helge-mueller.de/forforum/1142400.jpg and http://www.hans-helge-mueller.de/forforum/1142600.jpg
But all hints my be helpful in future for me and others.
@Neel
Your first link http://takeoneflix.com/ulead-photoimpac ... e-objects/, opens, however clicking on the video to play it, gets a No Entries Found message.
Neel,
I just tried also, the Large thumbnail leads to a page headed "no entries"
nmehta
Post by nmehta »
Folks,
I have fixed the problem and the video works correctly now. Thanks for pointing this out.
Neel Mehta
