Hi everyone,
I am a newbie, just bought a new Acer PC with Vista. I upgraded my VS8 to VS11 to work with Vista yesterday via the online upgrade. I have successfully created my first project with some MPGs, JPGs, a little music and 3 or 4 transitions and I am looking to burn a DVD. I successfully burned a DVD for this project yesterday, but today when I am burning a DVD from the same project, I am getting an error.
I am creating a very basic DVD of my project, single menu item, the video is only about 10 minutes long.
By watching the DVD creation screen, the project is about 60% done, it has just finished creating "menu transitions", and I get this lousy error:
Unspecified Error
[5:0:0]
The program doesn't crash, it just goes back to the disk burner screen.
This is really disappointing, to say the least.
Has anyone seen or heard of this?
Thanks in advance,
Mike Thompson
Ottawa, Ontario
VS11-Vista-New PC - Burning DVD - "Unspecified Error [5
Others have reported problems when they have used some of those special menu animation effects. I have never used them and so have not had the problem. I know this does not answer the question of why it worked once, but not the second time. But try making a menu without the menu transitions.
Also, you might want to render your project (Share > Create Video File > DVD) *before* you even open the burning module. Then, when that new DVD compatible mpeg-2 is produced, close your project by opening a new one. Don't bother giving it a name -- the objective is merely to clear the timeline.
Then go to Share > Create DVD to open the burning module. Use the Add Media button to insert your new mpeg-2 in the burning timeline. Make sure 'do not convert compliant mpeg files' is ticked in the middle of the three icons in the bottom left of the burning screen. Then, as I suggested, make a menu without animations... And let us know what happens.
aliendaddy
Success!
Fantastic! I tossed the fancy transitions (for now) and rendered an MPEG-2 file successfully. (about 400Mb). Then, I closed the project, started a new blank one and imported my MPG back in, nice and clean. I selected the default menu (for now) and successfully burned a DVD.Ken Berry wrote:Others have reported problems when they have used some of those special menu animation effects. I have never used them and so have not had the problem. I know this does not answer the question of why it worked once, but not the second time. But try making a menu without the menu transitions.
Thank you very much for the walk thru. I'm learning how this software and rendering process works now, and it is making more sense. I will try a new project with a few transitions in it, and select a slightly fancier menu layout and try again to see of that is causing my issue. I will do the rendering and burning in separate processes however, since your explanation of burning in a clean timeline seems to work so well.
Thanks again, and regards from Canada.
Mike Thompson
Ottawa, Ontario
RocaWear_Chulo
RocaWear_Chulo
Welcome to the Forums Eddie,
First we are going to need some more information. Please view This Thread, it provides a guideline to the specific information needed to help you.
This becomes especially important, since things work so differently between Vista and XP.
I have had a very similar problem to Eddie. I have learned to work around it, but hope to find the reason and solve it when time permits.
Eddie, I got that error message when I was trying to render a video where I was using random transitions. The problem I had is that when I reloaded VS11+, I had to do it a few times for various reasons, it did not have the library files for all of the transitions. Not related to the menu effects, this is the transitions between clips. When I removed all of the transitions from my project it would render fine. What I ended up doing, which was painful because I was creating an 1,800 transition clip, was to verify every transition before going to render. When I would click on the transition and run it to make sure it would work. I found that if the transition was faulty it would just show black when I clicked on it and not the clips. It was still painful.
I hope to reinstall, be lucky, and get all of the transitions loaded. But I did notice that everytime I had to reinstall I seemed to get les and less transitions.
I hate to think you are having the same problem. I don't think this is very common, because I have not seen many things like this on the forum. Your reference to "failed to load library" was the key for me.
Bruce Bennett
VideoStudio 11+ (started with VS5)
PhotoImpact 12 (started with PI11)
