Files did not self register
drewbdo
Post by drewbdo »
I was having the same issues as others installing video studio 11 and having a fatal error. I installed manually as suggested but when installing the AVcontrolSDK I get an error of the following:
Program Files\Common Files\Intervideo\Common\Bin\Dispsvr.dll
Specified module could not be found
Program Files\Common Files\Intervideo\Common\Bin\IVIVIDEO.ax\
I am unable to capture video or use the part of the program tto make menu's etc.
I am using Windows XP sp2. I also have Video Studio 9 installed.
Your help is appreciated!
Could I ask that you copy the above post into this link please:
avcontrolsdk - Your Help is Required.
Thank you.
Reminder: That link is for DATA gathering only
You might find a cure in this thread:
Fatal error when trying to install trial version of VS11+
drewbdo
Post by drewbdo »
Thank You...
I did read the thread you suggested...that is where I discovered how to install them seperatly.
Thanks,
have you tried to register the file manually.
Please view
Register a DLL
From the windows START button select RUN
in the RUN dialog box type
regsvr32 "c:\Program Files\Common Files\Intervideo\Common\Bin\Dispsvr.dll"
By the way my copy of Dispsvr.dll is located at:
C:\Program Files\Ulead Systems\Ulead VideoStudio 11\AVControl
Therefore on my machine the command would be
regsvr32 "C:\Program Files\Ulead Systems\Ulead VideoStudio 11\AVControl\Dispsvr.dll"
Svuppe
Post by Svuppe »
Perhaps we have a new clue to this mystery right here?
I am one of those having the install problem, and I'm pretty sure I remember seeing my AVControl files in Common Files too. I just have to double-check when I get home tonight.
For some reason some users seem to get AVControl in Common Files, and others have it within the VS program folder. What if the install problems are directly related to the first group? Just a thought.
drewbdo
Post by drewbdo »
I tried to self register the files and received the following error:
LoadLibrary("c:\Program Files\Intervideo\Common\Bin\Dispsvr.dll") failed - The specified module could not be found
Did you try:
You can also search your hard drive(s) for Dispsvr.dll to see if and where it is located on your machine.
drewbdo
Post by drewbdo »
Thank you for your patience...
I tried what you had suggested...I checked and the file is located in "c:\Program Files\InterVideo\AVControl
Try:
regsvr32 "c:\Program Files\InterVideo\AVControl\Dispsvr.dll"
drewbdo
Post by drewbdo »
I tried and the same result as before:
LoadLibrary("c:\Program Files\Intervideo\AVControl\Dispsvr.dll") failed - The specified module could not be found
Try renaming your copy perhaps to Dispsvr.old
Then install this copy from my computer and see if this one will register
http://media6.filewind.com/g.php?filepath=13642
If it doesn't you can delete mine and rename yours back again
drewbdo
Post by drewbdo »
Still the same error message as before
All I can suggest at this point is the clean reinstall procedure;
Please click here
drewbdo
Post by drewbdo »
Finally Fixed!!!
Thanks to BrianCee as I was watching for others on the board having some of the same issues...turns out I needed to update the DirectX drivers on my computer.
Can I unistall video studio 9 after installing video studio 11 or does the upgrade use some files from the video studio 9 edition?
Post by Trevor Andrew »
Yes you can uninstall VS 9, but as you suggest you may have problems.
If So:- this should be restored by running a repair for VS 11. ( there are some common files)
I would recommend running both VS 9 and 11. for the time being.
Many users run several versions of VS without problems.
In my opinion VS 9 is the best of the bunch.
