I have the Sony HDR-UX1 AVCHD DVD disc model.
So we don't have the same model of camcorder.
However, I can share some insights.
First, I believe it is
essential for me to use the Cineform .avi codec -- a $250 purchase -- to get decent AVCHD editing functionality in Corel's VideoStudio 11 Plus or Corel MediaStudio Pro 8.
Workflow steps:
1. Transfer the AVCHD files from the camcorder "disc" (or memory card in your case) to my computer's hard disk. I can do this successfully using either the Corel VideoStudio 11 Plus "Import From DVD" command or by using the Sony "Picture Motion Browser" software.
2. Transcode the AVCHD files to Cineform .avi format.
3. Edit.
4. Export to either
WMV HD or
HD MPEG-2
5. Distribute. (WMV HD can be distributed as a data file on any type of disc; HD MPEG-2 can be distributed as an "HD DVD" image burned to a normal DVD).
As for your question about playback of "HD DVD" discs, you should know that
a normal DVD player can't read an "HD DVD" disc... even if the "HD DVD" disc image is burned to a normal DVD.
Yes, you can "down-convert" your HD timeline to standard definition MPEG-2 and then burn a normal DVD that will play in normal DVD players.
To play an "HD DVD," you will need an "HD DVD" player.
You can give your target audience an option to see high definition video by burning a WMV HD file -- as data -- to a normal DVD disc, which can be played on a computer with Windows Media Player.
For me, it is essential to use the Cineform codec because -- in my opinion -- there is a long GOP smart render bug that makes the native editing of MPEG-2 impractical.
Jerry Jones
http://www.jonesgroup.net
