producing DVD pal
brayspeed
producing DVD pal
Post by brayspeed »
I would like to know if there is a better way,
1/. I capture in dv/avi as i down convert from hdv to dv
2/.project properties are
PAL (25fps)
MPEG files
24bits, 720 x 576, 25 fps
Lower field First
DVD PAL 16.9
Video date rate Variable (MAX 8000kbps)
Audio data rate 256 kbps
Dolby Digital Audio, 48 Khz 2/0(L/R)
3/ I place my project onto the time line
4/ goto share create disc and burn
would it be better to capture as MPEG
Tony
Post by BrianCee »
No do not capture a DV file as mpeg - capture it as DVavi
Your project properties are wrong if you are importing as DV then the second line should say "AVI files"
item 3 is OK
But item 4 should say "Go to Share >> Creat Video File and create DVD compliant video file"
Then item 5 would say "delete everything from the timeline"
item 6 would say "Go to Share >> Create Disc and import the new mpeg2 file and burn to disc.
jmone
motherboard: ASUS P8Z77-VPro
processor: i7 3770K OC
Video Card: ASUS GTX660 OC
sound_card: FiiO E10
Hard_Drive_Capacity: 60TB
Post by jmone »
I'm not sure how you capture HDV as DV...but I bring all my stuff in as HDV then edit and save the results in this format for playing on my HTPC. If I need to distribute on DVD then I take the selected clips and burn using a DVD template.
Nathan
