I want to send a video to my Sony PC100E via Firewire. I don't get any error message, but ther is flickering and some blue screen for about 2-4 seconds every 20 seconds.
I tried to reinstall the programm, the dirver of the firewirecard, defrag, tried a small video (about 200MB, the other one has about 12GB) many tools to clean my system, no success.
What can I try...
System:
WinXP, all SP, VS11 Trial, 2 HDDs (System/Files, each 250GB), what else is important?
I tried to capture and it works fine....
What could it be?
Thank You
Rupert
Problems Output to DV Camera
skier-hughes
- Microsoft MVP
- motherboard: gigabyte
- ram: 4GB
- sound_card: onboard
Let's start by ensuring the cam does have dv-in enabled, does it?
Has it worked previously?
Have you tried another cable, as it could be something has got damaged and is not allowing the transfer back of info, so you really need to check the pc and cam ports as well by testing other known to work items.
dagobert
skier-hughes
- Microsoft MVP
- ram: 4GB
Just because camera to pc works doesn't mean pc to camera will, any of the three components can have developed a fault stopping it.
So it has worked properly before?
With the same pc?
Could be the pc can't cope with the strain of sending it back. Have you tried making an avi file and putting this on the timeline and sending that to the cam, in case there are too many transitions/effect for the pc to cope with in real time?
Have you turned all other things off?
This may help
http://www.myvideoproblems.com/Tutorial ... rVideo.htm
With the same pc?
This may help
dagobert
Hi Graham,
thanks for the fast answers.
It didn't wok properly before, I just installed the firewire card one day ago.
I turned off all tasks i could identify. The avi - file is a simple, completely rendered file, so I just export the file, not from the timeline (btw. I tried it, but I can't export anything from the timeline)
I will try the hints from your Page... Lot's of work to do...
Rupert
Rupert
skier-hughes
- Microsoft MVP
- ram: 4GB
dagobert
