I had the Canopus DV Raptor card years ago.
Excellent card.
But you'll likely have a difficult time getting it to work with Corel VideoStudio 11 Plus.
Here's why.
Most modern Firewire cards comply with the "Open Host Controller Interface" specification, which supports Microsoft's DirectShow architecture.
All of Corel's video editing applications are designed to support Microsoft's DirectShow architecture.
So any Firewire card that complies with the "Open Host Controller Interface" (OHCI) standard will work with the Corel programs.
The Canopus DV Raptor does not comply with the OHCI standard because that card was designed to work with the older "Video-For-Windows" architecture using a proprietary software driver from Canopus that could only work with programs it was specifically designed to support.
Canopus originally bundled the DV Raptor card with Corel (formerly Ulead) MediaStudio Pro version 5!
Canopus then updated the driver -- as I recall -- to make the DVRaptor compatible with version 6 (and maybe even version 7).
But then Canopus decided to stop working with Ulead and instead work with Adobe (while working on proprietary Canopus editing applications).
I don't think the Canopus DV Raptor driver was ever written to support any of the VideoStudio versions.
So I suspect you may be out of luck with that particular card.
It was a great card; very stable.
But it is terribly outdated in many other ways.
Due to the fact it doesn't support DirectShow architecture, it doesn't support very large file sizes in the same way that an inexpensive OHCI-compliant DV card of today can.
As I recall, the Canopus team devised a clever way to get around the file size limitations of Video-for-Windows.
But as good as the card was, it's really obsolete these days.
You can spend $50 for an OHCI-compliant card that will be supported by all of today's software.
Jerry Jones
http://www.jonesgroup.net
