Burning Problem
scizz
Burning Problem
Post by scizz »
Hi Everybody, pls help.
I use VS8 SE, everything is ine until I burn to the DVD...
It goes fine until it reached 100% and then sticks at 100%
My brothers does not havethis problem on his pc, his ejects he disk once it has completed the burn. I have to force VS to close down as the DVD drive continues to go mad even though the program says that it is 100% complete. After I restar VS, the DVD plays on my pc but not on my DVD player conected to the pc, any suggestions?
jchunter
Post by jchunter »
Are you manually setting the Burn properties to match the your project video file properties as recommended in the top post?
scizz
Post by scizz »
no, but will that efect the burning?
THoff
Post by THoff »
scizz wrote:no, but will that efect the burning?
It can indirectly cause problems.
UVS V8.0 had a memory-leak bug (it's fixed in V8.01), and if the video has to be re-rendered because the input and output properties don't match, you are more likely to run into this issue. Apply the patch, and keep an eye on the amount of free memory using Task Manager.
jchunter
Post by jchunter »
Schizz,
Video editing is all about controlling video properties. If you are not managing them, Video Studio defaults will be applied, which have nothing at all to do with your captured video. You will get garbage and you will be frustrated. The Recommended Procedure in the top post was written to head off problems with the many bugs and design flaws in Video Studio. Follow it letter if you want quality DVDs.
John
scizz
Post by scizz »
Thank u for your assistance
