Importing MSP7 dvp files into MSP8
Aranya
Post by Aranya »
Hi, I've just upgraded from MSP7 to MSP8 & am looking forward to using the extra opportunities that it offers me. However, I am unable to open any of my MSP7 dvp project files in MSP8. Is there a way of doing this? - I assume so, else I'm guessing that the file suffix would have been changed with the new version. Any help would be much appreciated, thanks. David
cgould
Post by cgould »
DVP files should open just fine (as project files), actually the usual problem is forgetting and opening one in MSP8 and saving by mistake, then MSP7 won't open them any more (they're not forward compatible.)
Don't open it as a video file, open as project.
Devil
Post by Devil »
There are some features in MSP 7 which cannot be translated to MSP 8. In particular, titles are not compatible. It has always been recommended on this and other forums to finish all MSP 7 projects in MSP 7 and start new ones in MSP 8.
Aranya
Any ideas how the following happens?
Post by Aranya »
Thanks for the reply, but alas that wasn't proving to be the case. However my subsequent investigations have now found the cause (though I'd appreciate an explanation if anyone has one)... :D
I was indeed trying to open them as projects, but I just got the message 'File reading error' with the number 20379:1:107. This happened with both backups of the project that I really wanted to do more work on. As both files still opened fine in Video Editor 7 (which was left on my PC when MSP8 was installed), I started there. I tried removing the CG Infinity created intro (as I see it is no longer bundled with MSP8), but that made no difference. Then I remembered that when I did a first render on this project, one of the clips on the mpg had corrupted sound. I figured that it was an issue that occurred during rendering & nothing to do with the original clip (as it sounds fine played in video editor 7), but I thought I'd try deleting it & saving the dvp file again & hey presto! it now opens in MSP8!
So... does anyone have any idea what might have been the problem with the corrupted clip? (I have used clips from the same original interview / avi file, elsewhere in the project - so why the issue with just this one?).
Many thanks. :D
Aranya
Titles
Post by Aranya »
Thanks Devil, Having got the project to open, the titles seem OK (before rendering), but it might be just as well to redo them then... at least now I don't have to recompile the whole project manually! :D
eddylik
Post by eddylik »
I have the same problem, I would like to edit my MSP7 file with my exsisting software MSP8, but can't open, can anyone hlep please?
Aranya
MSP7 to MSP8
Post by Aranya »
Hi Eddylik,
The issue for me was a corrupted avi file, which when removed from the project on MSP7, allowed the dvp file to be opened on MSP8. Have you tried rendering it in MSP7 & see if it plays OK all the way through? That was how I found the audio problem on that one file.
Good luck!
Aranya
