Photoimpact uses nearly 100% of CPU, even when idle
johnmeyer
Post by johnmeyer »
I upgraded from XL to Photoimpact 10. Other applications suddenly seemed sluggish, so I opened the Windows task manager and found that "Iedit.exe," which is the main Photoimpact task, is using nearly 95% of the CPU, even when Photoimpact is just sitting there.
I downloaded and installed the patch to upgrade to 10.0.0.1, but this didn't change anything. I am running XP Pro SP1.
Does anyone else see this behavior?
johnmeyer
Post by johnmeyer »
I got advice over at Stephanies' site, and decided to uninstall and re-install. I tried a "repair" install first, but that didn't help. I then did a complete un-install and then a re-install, and things are working correctly again.
johnmeyer
Post by johnmeyer »
Phooey. I posted too soon. The problem is back, even after the re-install.
klowther
Post by klowther »
Does it only happen when you have an object highligted and the selection marquee is active? Try disabling the marquee (shift-f12) and see if the problem goes away.
Hope that helps.
- Ken
roa3
Post by roa3 »
oh...
so Iedit.exe is from ulead...
No wonder my computer always ran out of memory...
Sucks
