'Convert to Disc Template' greyed out, .mpeg, .ac3 help
torana_79
Hello,
Im in a real bind here, i some quicktime files created on a mac using Final Cut Pro (24bits, 720x576, 25fps). The files are imported fine and i can burn the finished project to dvd but when it comes to playing the video there are ever so slight jerks consistently thoughout it.
From reading the forum i though unchecking the 'Convert to Disc Template' option in the Edit option of DWS2 would prevent re-encoding and perhaps solve this problem but... its greyed out?
Dan
Dan
torana_79
That's not the problem...
Workshop will convert your files without giving you a choice, because your Quicktime files are not DVD compliant.
Try saving your file (from Final Cut) in MPEG-2 instead of Quicktime. I assume that Final Cut gives you a choice called "MPEG-2 DVD", or something like that. (Not all MPEG-2 is DVD compatible.)
720x576, 25fps is good for a PAL DVD. You also need DVD compatible bitrates and GOP size... and maybe some stuff I don't know about...
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
torana_79
Hello DVDDoug,
I am getting some of the quicktime files output as MPEG-2 instead of quicktime, i will double check that the MPEG-2 is dvd compatible.
Im not sure what GOP is but i have been told a calculation on how to work out the best bitrate for the video in the dvd.
560/Total Time - 1.5 = video bitrate
I guess i am a bit of a newby at this.
Thanks for the heads up.
- ram: 2 GB
- sound_card: Intel GMA 950
GOP = Group of Pictures. It is a MPEG format thing - part of the compression algorithm
Here is an explanation:
Wikipedia
Or in "English"
The I frame is a complete picture. The next few frames ( P and B frames) contain changes to that picture until you reach the next I frame - normally about 15 frames apart. Its a way to try and reduce the overall file size.
Wikipedia
Or in "English"
torana_79
Thankyou sjj1805, that makes sense. So the more frequent the I frame the larger the frame but better quality to some extent.
If the output video is jerking at regular intervals when panning, then possibly the I frames is too far apart?
What would be a good start? 15 frames between I frames or is it more of a trial and error thing?
Dan
Dan
- ram: 2 GB
There is a comprehensive article here by Terry Stetler
MSP/VS/MF: Encode MPEG's from clips with fast motion
torana_79
The only resaon I mentioned GOP was to point-out that sometimes you think you have an MPEG that is DVD compatible, but Workshop still wants to re-code it...
* That works-out to one new I-Frame every 1/2 second, for NTSC video, which is 29.97 frames-per-second.
At first you might think so, but.... no. Since the bitrate limits how much overall data is being used for the video, and I-frames eat-up more data, there is less data available for the other frames. By choosing a smaller GOP size you are forcing the MPEG encoder to make "different" compromises. It might look better or worse, depending on the source material.So the more frequent the I frame the larger the frame but better quality to some extent.
I don't know what would cause that, but I doubt it's the GOP setting.If the output video is jerking at regular intervals when panning, then possibly the I frames is too far apart?
That should be OK. (Most of my MPEGs are 15*) I don't remember exactly, but I think the DVD spec requires the GOP to be less than 18. I'm not sure if there's a minimum. And, it might be different for NTSC an PAL.What would be a good start? 15 frames between I frames or is it more of a trial and error thing?
No time to think.
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
torana_79
Thanks DVDDoug, i got the files exported as .m2v burnt a test without ulead compression and worked a treat. But...
im probably getting way of topic now but the dolby sound file (.ac3) will not import to ulead, its giving me an invalid format error... I installed a few filters and can see it in my add remove programs (ac-3 acm codec, AC3Filter). The files were created on a mac using final cut pro. I also have an .aiff file but do not have the option to import it with ulead. Final cut pro doesnt seem to output wav files.
I am going to have to convert all the .ac3 files to .wav unless i can work out a fix for this.
Thanks again for all your ongoing support, i will edit the original post subject heading so its relevant.
If you have a dvd compliant mpg file with valid ac3 audio, WS2 will NOT re-encode it, unless you force it to.
