Sam
relinking with ulead 7
sammy boy
Hi, I am having problems with relinking clips in my libary manager on a ulead 7.
I am not sure how relinking is surposed to work but have tried just about everything, any clues would help.
Sam
Sam
l-upward
relink
Sammy
I have the same problem in VS8. I opened a big project with about 150 clips and it gives me the message "original file does not exist". When I click on relink it invites me to open each clip but I can only do this individually. I am unable to highlight all clips at once. Why are my links lost? I haven't had this problem before now it has happened to all my projects
MikeGunter
jchunter
This is the way I do it. Load a project and if you relink one file, VS will usually relink all the others. Select all the associated library icons and press the delete button, deleting ONLY the icon, not the file. Then select all the lnked clips in the timeline and drag them to the library en masse.
BTW, I have learned from sad experience to keep projects small (5 - 15 min.) because they are much easier to edit, then make the DVD from several project video files.
John
John
THoff
Guys, you are both right -- it's both.
UVS looks for changes to the file, which it unfortunately does by examining file sizes and timestamps, and when DST goes into or out of effect, the local time of the file changes by one hour. That's a bug, plain and simple.
The other way for the library to prompt for a relink is of course a change in the drive letter assignments (usually of removeable / external drives), which will change the path to the file. That's not really a bug.
