WinXP 2GHz PC
I'm this close >> << to buying VS11+, but if I can't make a DVD file with the trial, I'm going to look elsewhere.
I fixed my "preview" problem by installing DirectX9c (thanks for the info in another topic in this forum!)
My issue now is that I'm trying to create the DVD files. After about 2:30 minutes of crunching numbers, VS11+ crashes. The dialog says nothing much other than the application caused a shutdown.
I tried saving the files to a different path and different drive, but no luck. I even install VS11+ Trial on a different PC and got the same problems (it won't make the DVD files.
