An omition.
MikeB51
- motherboard: Foxconn - A75M
- processor: AMD A4-3300 APU X2
- Video Card: ATI Radeon HD 4800 Series
- sound_card: High Definition Audio Device
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung SyncMaster 23 vis
An omition.
Sorry I should have said I'm using VS 10.
- jparnold
- motherboard: Gigabyte Z390 UD
- processor: Intel Pentium i7 9700 3dot6Ghz
- ram: 16GB DDR3
- Video Card: Gigabyte RTX2060 OC 6GB
- sound_card: Onboard Realtec ALC887
- Hard_Drive_Capacity: 2048Gb mix
- Monitor/Display Make & Model: Samsung S27C450B
- Corel programs: Videostudio X10, Paint Shop Pro 2018
Hi Mike
Just letting you know that if you want to add something to a previous post you entered you cane select your post and then hit the EDIT button and change it rather than create another post which is a bit of a waste.
I cannot suggest anything regarding you initial post except to re-render the shorter clips together and then import them into a project where they will be long enough for a normal transition.
John a
