Vitual Memory/page/swap file
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
At present I have 1.5 GB ram.The VS11+ manual tells me to set the min + max value to twice my ram.In a recent article in a computer magazine
it reccommended 2034MBmin +3072max.Is this not an excact science here or is it just guess work.What are the advantages/consequences etc of setting a lower min than double the ram regards Ken
Twice your RAM is old and out of date advice now. Imagine some users who have 2GB (or more) of RAM!!
Please view:
Virtual Memory Optimization Guide
jparnold
motherboard: Gigabyte Z390 UD
ram: 16GB DDR3
Post by jparnold »
Wow that article (Virtual Memory Optimization Guide) is a big read.
One thing which is important if you change your paging file (and pointed out in the article) is to DEFRAGMENT the hard drive before creating/changing it.
I do that by disabling the paging file (this is ok if you have at least 256Mb ram) then Defragment the hard drive then set the paging file to a value. I set mine to 1.5 times ram and set the MINIMUM and MAXIMUM size the SAME. I read somewhere that by setting the paging min and max size the same you avoid fragmentation of the paging file. I can't see how this can be but I think that it can't hurt even if it makes no difference.
John a
You read it in that article.
What it means is that a chunk of your hard drive is reserved for a swap file, no matter how large or small it is, nothing else uses that area.
(Unless your hard drive gets full)
Ken Veal
ram: 32 GB
virtual memory
Post by Ken Veal »
Thanks for the link steve, I think I now know all I need to know about paging and swap files.Since posting the memory question I have installed 3GB of ram.I still need clarification though on how much I should set the min + max values to or if I need any at all.Will any applications actually need paging/swap files.Would it be wise to let XP by default control the files even if this would take up some processing power.
As for this being old hat it does rather beg the question why is setting to twice the ram being published in the manual of Uleads latest video editing software regards Ken
If you right click "My computer" and select 'properties', 'Advanced' and then select 'Performance Settings'. 'Advanced' 'Virtual memory' [change]
What do you see near the bottom of the dialog box next to "recommended"
According to Microsoft you still need a paging file - even if it is only a very small one.
