No Audio With CHapters
Dantor
Post by Dantor »
I created my menu with chapters. I go into the player and play it and click on each chapter and audio plays, when I burn it and play it in the player there is no audio with chapters. There is audio on the first part of the chapter one.
I have checked foroum for a thread about this but have not found any. :)
DVDDoug
Moderator
Post by DVDDoug »
I suspect you have a (slightly) corrupt MPEG file. You are feeding Workshop an MPEG file, right? A corrupt MPEG file will often play OK, but cause trouble when you try to edit it, convert it, or make a DVD from it.
I also suspect that this has nothing to do with adding chapter-points, although a corrupt MPEG might cause more trouble when you "skip-ahead" rather than playing it in sequence frame-by-frame.
Both VideoReDo and Womble include repair tools that can fix some MPEG problems. And, both offer free trials.
You also could try splitting-out the audio to a WAV file (with Video Studio, Media Studio, etc.) and then use that WAV file for the audio track on your DVD. But, that may not help if the problem is not specific to the audio stream in the A/V file.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
Dantor
Post by Dantor »
I think I have narrowed it down to the playlist. I found out if you don't add the 3,4 and 5 chapter to chapter 2 in th eplaylist then it will not play from that chapter. I'm burning now.
GeorgeW
Post by GeorgeW »
Are you talking about Chapters, or Titles :?:
Titles are separate video clips that you add to your project.
Chapters are "jump to" sections of a single Title.
If you are talking about Titles (separate video clips), do they all have the same type of audio :?:
George
Dantor
Post by Dantor »
I'm talking about Titles. I keep getting that turned around. So I don't have audio with my Titles.
DVDDoug
Moderator
Post by DVDDoug »
I'm burning now.
FYI - You should be able to experiment without actually burning a DVD. On the burn screen, there is an option to Create DVD Folders. That will create the AUDIO_TS and VIDEO_TS folders on your hard drive. (You can un-check the Burn Disc box.) You can play that "DVD image" with your DVD-player software.
If you get that working, you can burn those folders to an actual DVD without re-rendering.
No time to think.
Out of... sync.[/i]
GeorgeW
Post by GeorgeW »
Dantor wrote:I'm talking about Titles. I keep getting that turned around. So I don't have audio with my Titles.
George
Dantor
Post by Dantor »
The one I just burned did not work. I go to the player in Finish and play and click on my Titles in the menu there and the audio is there.
My first Title has audio on it. I have scrubbed through and alll audio is there and seems fine. Anymore ideals? :D
Dantor
Post by Dantor »
George
No they don't all have the same type of audio, its just one long audio file with the video. Also it is DVD Type2
GeorgeW
Post by GeorgeW »
George
1) is that DVD supposed to be DV .avi :?:
2) does each separate video have audio, or are you trying to use one long audio track for all your separate video clips?
3) Pleas rt-click all the clips, and post their attributes here.
4) also let us know if under the VIDEO and AUDIO tabs, does the "Convert to disc template" stay ghosted (meaning they will be converted to project settings)
George
Dantor
Post by Dantor »
GeorgeW wrote:
Dantor wrote:
GeorgeW wrote: If you are talking about Titles (separate video clips), do they all have the same type of audio :?:
George
Yes
One long audio track
Not available right now.
Yes they are ghosted
George
Dantor
Post by Dantor »
DVDDoug wrote:
I'm burning now.
The folders are there and the video and part audio is there. It's just like the burned DVD.
GeorgeW
Post by GeorgeW »
3) Please rt-click all the clips, and post their attributes here.
When they are available, please post their attributes here.
I might be reading this wrong, but it sounds like you are trying to use ONE long audio clip for MULTIPLE shorter video clips :?:
George
Dantor
Post by Dantor »
Hi George,
I think I got it. What I was doing was using the template from a old project and just droping my video in and using that old menu.
I got to thinking that this might be corrupt somehow, so I went ahead and created a new menu with titles and it burned with audio.
I'am using one long segment of audio with one long segment of video setting the I Frames in ULead.
Anyway seems to be working. Thanks for your help. If it acts up I'll let ya' know.
