is there any way (or workaround) making it possible to run PI7 under Vista?
I've tried it: The program actually does install and start, but won't work properly then ...
To me, 7 has always been the "gold version", and I've been missing it ever since installing Vista.
Thanks Jens
PI7 under Vista?
JensMahlmann
- ram: 2 GB
- sound_card: Intel GMA 950
I think you are out of luck.
If you check the Corel Knowledge base
It only lists PhotoImpact 10 / 11 & 12
PhotoImpact 7 will be considered an out of date product.
PhotoImpact 10 doesn't run on Vista and since PhotoImpact 7 was not intended to run on Vista primarily because it was made years ago, when isn't available yet -- it won't. Maybe it installed because the components it need can be found at vista, but it isn't supposed to happen.
I you think PhotoImpact will do a lot of help to you, then why not invest on PI12 perhaps?
I Rip. I Burn. I Conquer.
heinz-oz
JensMahlmann
Got 12!
@robruiz: Actually, I do have PI12. It's just I liked PI7 much more - if only because it was much faster (and more stable, too)!
@heinz-oz: I have tried compatibility mode, but it didn't help running the prog.
Regards
Jens
Regards
Jens
heinz-oz
Re: Got 12!
Too bad Jens, blame VISTA, not PI. Pi 7 is a very old version and no longer supported with update patches etc. Try a dual boot set-up with WIN XP on the second boot. It should work in that.JensMahlmann wrote:@robruiz: Actually, I do have PI12. It's just I liked PI7 much more - if only because it was much faster (and more stable, too)!
Regards
Jens
