amending UVS Transition Effects
cwpaters
i wish to change the F/X transition the "Fade to Black" transition. I want to change the color from "black" to "white" so the effect will probably be called "Fade to White"
Can this be done?
Can this be done?
lancecarr
- ram: 12GB
- Hard_Drive_Capacity: 700GB
cwpaters
lancecarr
- ram: 12GB
cwpaters
- ram: 2 GB
- sound_card: Intel GMA 950
Instead of a black color block use a white one and do it the way shown here:
VideoStudio - Fade in/out of a clip
lancecarr
- ram: 12GB
Hi Steve,
No we have kind of been down that path. The OP was looking to be able to actually change the "fade to black" transition itself into a "fade to white." Or even locate a "fade to white" transition.
He is doing a kind of "highlights" reel that will involve the effect being used a huge number of times so was looking at a faster method than the old insert white matte, crossfades at each end one.
He had the idea there may be a way to "hack" the "fade to black" transition" but this is beyond my meagre skills!
- ram: 2 GB
PeterMilliken wrote:And if you really can't find anything in the ULead or Burger transitions that suits your need then you can (apparently) create your own by downloading the SDK (free) - this is how I believe the Burger transitions were created
Have a look at http://www.ulead.com/download/sdk.htm
Peter
Original thread:Stefan_Burger wrote:Transition effects are small programms, so called 'Dynamic Link Libraries' or aka 'DLL'.
You can write your own transitions if you have some skills in c++ programming and also some skills in 2D and/or 3D graphic algorithms.
Some creativity and spare time is also usefull. Not to forget patience and endurance, as things almost never work at the first attempt and sometimes not even on the second or third attempt.
Stefan
http://phpbb.ulead.com.tw/EN/viewtopic. ... ght=#37177
Steve, it's funny you mention Burger's. Stefan has a BW Transition.
Burgers TransitionsTransition BW Flash: Scene A fade out to black, then scene B fades in from black to a certain degree of white and back to scene B.
Jeff
Dentler's Dog Training, LLC
cwpaters
lancecarr
- ram: 12GB
Here's a possible workaround...
First create your Fade to white..
- Place 2 white color blocks in the main timeline.
- Place a cross-fade transition between the white color blocks.
- Adjust the duration of the color blocks to about 18 frames.
- Adjust the transition duration to about 15-18 frames.
- Render this to an AVI file. I used DV type 1. Name the file something like f2w (fade to white).
- Start a new project, insert your video or images into the timeline.
- Now for the transition drag the f2w.avi to the timeline, placing it between video/image clips, just like a transition.
- Place a cross-fade transition between the video/image clip and the f2w.avi clip.
- Adjust the duration of the f2w.avi clip by dragging the yellow handles.
