vs11 crashes when I try to delete thumbnails
confused user
Post by confused user »
When I try to delete thumbnails of files that are corrupted VS11 crashes. Is there a workaround or do I have to leave the thumbnails in the library? I can't even click the thumbnail without the crash occurring.
confused user
I solved the problem
I deleted the corrupted file from my computer and then the thumbnail was able to be removed.
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
What was the corrupted file?
I ask in case someone else has a similar problem and your solution might help them too.
confused user
corrupted file
Maybe that's not the correct term, but when I tried to import a dvd+r dl made on a video converter, the second layer imported fine and the first layer looks like it imported and then won't play. I remade the dvd and tried again and the same thing happens. I'm going to try to import a different dvd+r dl and see if it occurs.
confused user
not sure anymore
I had no problem with the next dual layer dvd, so I'm going to assume the file size was too large and the file wasn't corrupt. Is there a file size limit for importing into vs11, and where would I find out the info.
Re: not sure anymore
confused user wrote:I had no problem with the next dual layer dvd, so I'm going to assume the file size was too large and the file wasn't corrupt. Is there a file size limit for importing into vs11, and where would I find out the info.
No there isn't a limit - unless you are using a FAT 32 Hard Drive in which case the Operating system imposes a 4GB file size limit. You should be using a NTFS hard drive.
A dual layer DVD contains up to about 9GB of data.
A typical 1 hour DV file from your digital camcorder contains about 13 GB.
confused user
files size must be the problem
I can put in most file sizes but when I capture or add a video that's 8 gig my computer or the program freezes. Using 4 or 5 gig does not cause the problem.
