Camera not found with VS 11
PARALAX
Post by PARALAX »
Hello!
There seems to be a problem with my Laptop or Windows XP Home (SP2). My Laptop is a Toshiba Satellite SM30 with 1,6Ghz. Intel CPU, ATI Radeon 9700 and the latest K-Lite Codec Pack as well as the latest Catalyst driver. All updates are installed but I can't access my Sony TRV14E DV-Camcorder at all.:(
The device will be detected on the Fi-Wi Port correctly and I even can access and record Videos with the build in Windows Movie Maker. However I can't with Videostudio 11. All Options are marked and I can't choose any device. Another problem is that I'm loosing the audio stream and the programm crashes after quitting if I want to work with Moviemaker recorded material. I'm very dissapointed with this version which I even only could install without a "fatal error" when I install the InterVideo Application apart from the VS installation. I never had those problems on my AMD64 Desktop which is still working with an old Windows XP Professional version.
What can I do now for fixing the detection problem with the camera?
PARALAX
Post by PARALAX »
The installer totally seems to suck...
Why did you feel the need to install the KLite Codec pack? Those mega codec packs cause more problems than they are worth -- usually (and by the sounds of it with your most recent installation of VS11) by causing conflicts with other installed codecs so that nothing ends up working. Trying deleting the K-Lite pack and see if VS11 works better.
