Private Emails and Messages to Forum Staff.
I received the following PM:
Simple answer would be no. The reason is that DPI, Dots Per Inch does not apply to viewing on a monitor or TV. DPI only applies to paper, that's it, nothing more.DJBrunner wrote:On the post titled 'can I select photo resolution?' you replied with the following - 'It makes no difference what your image sizes are, once you insert them into the program, and create an SD (Standard Definition) video, then the images are down-res'd to match.'.
My question isn't about size but rather quality. Would the end result of what I see on my TV via a Picture Show slideshow be of a better quality if I scanned my photos in at 600DPI versus the standard suggested size of 300 DPI? They say that for making enlargements of a photo, say a 4x6 to a 5x7, that you should go use the 600DPI setting, but printing the same size or smaller to use 300DPI.
On one hand 600DPI is a higher quality than 300DPI, but on the other hand they suggest 600DPI only for enlarging existing pictures and yet you state that Picture Show downsizes them. Would the better picture quality make a difference?
Television and computer monitors use PPI (Pixels Per Inch). So if you have an image that you scanned at 600dpi, and want to view it in a slideshow on your TV, and your located in an NTSC area, and you're not creating an HD video, then your image is going to be 720px X 480px, that same image scanned at 300dpi is going to be 720px X 480px.
So printers use DPI, while PC monitors and TV use PPI. They do not relate to each other.
