*HELP* Another Mini DV Firewire issue JVC GR-D250
simc
Post by simc »
Greetings guys,
I have had a read of a large number of posts regarding Mini DV firewire connection issues, seems like a frequent thing.
I have come across the same thing with my JVC GR-D250.
The camera: 4pin firewire DV output. ( I have never used it prior to this). Appears to be no physical damage to the port.
The computer: Dell laptop, windos XP, 4 pin 1394 firewire port, device manager says its working fine.
The Cable: 4pin 1394 cable to 6pin, and then a 6 to 4 pin adapter plug, so that it plugs into the 4pin input on the laptop.
I have tested the cable with a multimeter, all pins are connect and correct.
When I plug the camera in (running off batt or mains supply) the PC does not detect the camera.
I do not have ay drivers or software specifically for the camera as it was not included when i bought it.... but are these required??? Should the PC detect it anyhow?
I have had no issues with transpering from a HD camera via usb, but my minidv just wont connect!!!
Help please :cry:
Firstly check your drivers:
Item 10 - Troubleshooting your computer
Any faulty items of hardware will have a yellow exclamtion mark :!: alongside them. If you do not have a driver problem then check to see if you are doing the following:
1. Camcorder turned OFF
2. Start VideoStudio
3. Goto Capture Tab.
4. Turn your camcorder ON and to PLAYBACK mode.
If the firewire connection is working you should get a message telling you that it has detected a new device attached to your system and inviting you to use it.
simc
Post by simc »
Just downloaded the latest trial version of ulead 11.
I did what you described above, and I have no driver issues relating to the firewire port.
I also ran Ulead and connected/turned on everything in the order you suggested, and it still did not work.
Error:
"Either no video capture driver is installed in this system or no device is connected"
Any other suggestions?
Possibly a faulty cable.
Do you have access to another computer that you can try the cable with.
Also try using Windows Movie Maker that is built into your operating system.
simc
Post by simc »
I will try it on another PC, probably over the weekend, or I will try and pick up another cable if I get a chance.
It is starting to sound like a cable issue as you mentioned as the camera and laptop are both pretty much still new. The 6 to 4 pin adapter might be the culprit.
Also, I have tried ulead 11, windows movie maker, and another two trial versions of DV capture software.... still no go.
Thankyou for your help so far, I will report back with an update.
It may be your adapter that is causing the problem. You should be able to pick up a 4pin - 4pin Firewire. Since your camera and laptop both use 4 pin.
simc
Post by simc »
IT WORKS!!!!
It was a cable issue.
The adapter i picked up from Jaycar Electronics CAT. NO. PA0910, did not work.
I swapped it for a 4pin to 4 pin CAT. NO. WC7640, and away she went!
Im very impressed with the quality and functions with my new toy.
Thanks for the help guys, you were a great help!!! :D :D :D
