MF 6 plus - crash on DVDMF.exe - uvHTMPEG2.dll
tizzy
Post by tizzy »
Hi Henry, thanks for the input and you're absolutely right, it is definitely a DVDMF.exe error (funny tho that it appears from the launcher regardless of whether or not anything is clicked). I'll get right onto the apps you name and also check if divX is not uninstalling properly. Just for clarities sake, you ARE also using 6.0? Cheers, Rick
tizzy
Post by tizzy »
snoops wrote:or Softella Filter Manager 0.5 can be very helpful with codec issues... if you know what you are doing.
This one worked! I used the troubleshooter page
and hey presto! like magic.
Thanks to all and of course especially Henry :D
Now if only the helpdesk were that friendly and willing :!:
snoops
Post by snoops »
Hi Rick,
Well, it doesn't matter anymore because the same problem would affect other versions.
But just for clarities sake:
No. I have MF5+ which I purchased at the end of 2006. I do not buy new versions all the time just because someone releases yet another update.
You never know, maybe I got another star in my Ulead report card after helping you on this issue, and will now receive MF6 as a gift. :idea:
Henry
barfarf
Post by barfarf »
I had a similar crash. However, the softelling filter did NOT work for me. In fact sofella software seems dated (made in 2005 I believe) and without proper updates or support.
I was tying to create menu for a xvid (similar to divx) file in MF 6.0 and it would crash after I push the burn button. It was a codec issue. What did work for me was using the Codec Tweak Tool which is part of the K-Lite Codec Pack. They are all FREE, highly supported and with good forums located at Codec Guidehere.
The moderation may want to add this tool to the free software list. Assuming there is one. Note: I personally use the full version of the K-Lite Codec Pack.[/url]
d-v-c
Post by d-v-c »
Find DVIX_UL.DLL in MF folder and change its name.
Thank you,
Steve
etech6355
Post by etech6355 »
Thanks, a good tip (for experienced computer users) but usually these add on codec packs cause and create more problems by installing them.
