Make Movie Templates Issue SUCCESS
Post by Trevor Andrew »
Hi Neil
Excellent, glad you got it working, and thanks for the information.
I have managed to simulate your problem by setting the file as ¡¥Read Only¡¦
Such a simple solution.
I believe the file in C:\Program Files\Ulead Systems\Ulead VideoStudio 11\Ulead.dat to be the default file, this is copied to Ulead Systems\Ulead VideoStudio\11.0 when you run a repair or delete MovieTem.dat.
Ensure the file in C:\Program Files\Ulead Systems\Ulead VideoStudio 11\Ulead.dat is not set as ¡¥Read Only¡¦
Thanks again
Philly55
Works for me!!1
Post by Philly55 »
Thanks all.
I checked the MovieTem in the Program file area -- it is not read protected.
I checked the MovieTem in the Documents file area -- it is read protected. I turned off the Read protection on this file and SUCCESS.
Thanks!
P.S. I wonder why I haven't yet heard from Ulead Tech support on this issue? Oh well . . .
Glad you got it working..:)
Curious though, did you unpack the install file, and just copy this one to your system? The installer should have removed the Read Only attribute. However doing a copy/paste from a CD/DVD, the attribute may not have been changed by the OS.
Philly55
Post by Philly55 »
I did not do anything different during install.
I did previously uninstall, and over the weekend, reinstall.
As stated I checked the file in the two areas and unchecked Read Only on the one in my Documents folder.
Best to you, Phil
jbomb
Post by jbomb »
I went through these steps and couldn't find the
MovieTem file through my windows search (except in the program files folder). Anyway... I found it located here
C:\Documents and Settings\MYUSER\Application Data\Ulead Systems\Ulead VideoStudio\11.0\
I set removed the read only attribute and it worked. Nice!
