Make Movie Templates Issue SUCCESS
iceritchie
Post by iceritchie »
When i try to make a template for a movie (Tools->Make Move Template Manager), i can create a template but when i go to the 'Create Video File' button, the template doesnt appear. When going back to the manager the template is no longer there. any ideas anyone? Thanks.
Can we assume that you gave the new template a name you would recognise, and then saved it?
jbomb
Post by jbomb »
I'm having the same problem. Also if I delete the two default custom templates they appear again when I launch the Make Move Template Manager.
iceritchie
Ken Berry wrote:Can we assume that you gave the new template a name you would recognise, and then saved it?
Yes i gave it a name. Pretty much followed sjj1805's method below but doesnt work using videostudio 11
Post by Trevor Andrew »
jbomb wrote:I'm having the same problem. Also if I delete the two default custom templates they appear again when I launch the Make Move Template Manager.
I would re-install VS, or at least do a repair restore.
iceritchie
Reinstalling didnt work. Maybe there is a bug in the software?
etech6355
Post by etech6355 »
Are you using Vista or XP.
If using Vista are you running the program as administrator or as a user.
iceritchie
etech6355 wrote:Are you using Vista or XP.
Im using XP.
does this work for everyone else or is it just isolated cases
I just tested this with VS11+ on my XP Pro computer. VS11+ has only been installed once to date. I went to Make Movie Manager, and set up a template for both the AVI option and the MPEG option, calling them Test01 and Test02. I saved each and pressed the Close button. Then I dragged a video clip into the timeline, and selected Share > Create Video File. Test 01 and Test02 appear at the bottom of the list, just above the final category 'Custom'.
So I am unable to replicate your problem.
Incidentally, I only had one template when I first opened Make Movie Manager.
iceritchie
Ken Berry wrote:I just tested this with VS11+ on my XP Pro computer. VS11+ has only been installed once to date. I went to Make Movie Manager, and set up a template for both the AVI option and the MPEG option, calling them Test01 and Test02. I saved each and pressed the Close button. Then I dragged a video clip into the timeline, and selected Share > Create Video File. Test 01 and Test02 appear at the bottom of the list, just above the final category 'Custom'.
Ken, thanks for your help. When you say 'saved each' is there a specific action to save before closing? I get the options of New, Edit, Delete, Close and Add when i have set up a template. I presumed close saved the template accordingly?
From Make Movie Manager:- I see two original templates one for Pal dvd16:9 and one for Pal dvd 4:3.
Once you have created the new template you click OK, it is then listed in the ¡¥Available movie Template¡¦ window.
You can select each template in turn to view the Properties in the lower window.
Select the ¡¥Close¡¦ option.
From Share-Create Video File, all templates are listed immediately above the ¡¥Custom¡¦ option.
I use the Make Movie Manager most of the time. I have not experienced any problems. My templates are always available.
Just a thought!
When you Share Create Video File, do you see any spaces below the first two default templates.
It may be that the names are missing.
If the program has not saved the templates then all you will see is the two defaults a line and Custom. No spaces. (grasping at straws)
iceritchie -- I select Make Movie Manager, and a dialogue box appears. I select New on it and a further smaller box appears allowing me to choose the format for the template. Below that is an empty line for the name you want to assign it. So give it a name, then click OK.
This takes you to a third box with 3 tabs on it. On the first tab (labelled Ulead Video Studio), all there is is a window with the Template Name you have just assigned (plus a specific size option below that is greyed out by default). You set the properties for the template in the other two tabs, starting with the third (AVI or 'Compression' if its to be an mpeg template) first, and then moving to the central one (General). Then you click OK again.
And this takes you back to the first dialogue box, but your new template name should now appear there. Click 'Close' to ... er ... close it. But next time you go to Share > Create Video File, your new template should be there at the bottom, just above Custom.
iceritchie
It appears to me that the file holding the new template is not being saved. It appears in the setting up windows during the initial creation, but doesnt appear in when selecting create video file. It also doesnt appear when going back into the manager tool. Does anyone know where these templates are saed and under what name?
