DVD MovieFactory 6 - Menue Backgrounds missing
871878
FRance
it should be there. if not, i suggest you try this:Located in the C:\Program Files\Ulead Systems\Ulead DVD MovieFactory 6\Ulead DVD MovieFactory 6\Content\Background directory.
1. Kindly remove MovieFactory 6 in the Add/remove programs.
2. After removing the program, go to this location and delete all folders:
"C:\Program Files\Ulead Systems\Ulead DVD MovieFactory 6.0"
"C:\Documents and Settings\All Users\Application Data\Ulead Systems\Ulead DVD MovieFactory\6.0"
"C:\Documents and Settings\[YOUR USERNAME]\Application Data\Ulead Systems\Ulead DVD MovieFactory\6.0"
"C:\Program Files\Common Files\Ulead Systems\DVD"
3. Click on "START > RUN...." and type in REGEDIT and press enter (you may not find the following keys after uninstalling the software but just to be sure, check them).
4. Locate the following registry keys and delete them by "right-click > delete".
HKEY_LOCAL_MACHINE\SOFTWARE\Ulead Systems\Ulead DVD MovieFactory\6.0
HKEY_CURRENT_USER\Software\Ulead Systems\Ulead DVD MovieFactory\6.0
5. Once deleted, restart the computer and reinstall the product.
*** Editing the registry could cause system-wide problems if critical keys are removed. Make sure you delete only what is mentioned and if you are not sure how to do this, skip this part.
Hope this would help. =)
871878
