could u tell me the bitrate for the video as i need to convert it again to vcd.
field used and compression...
harry_hariz
hi...im confused...i hav a video need to be edited...i might go wrong in its properies..the video is taken from vcd..i mean already in pal vcd n frame based...do i need to follow the field(frame based) and can i adjust the compression pal vcd that is 70% quality to mpeg 1 at 100% quality?
please help me...asap
- ram: 2 GB
- sound_card: Intel GMA 950
You will need a third party program to convert a VCD to MPEG
Then after editing you can adjust the quality slider to 100% - it will not improve the quality from its current level because you cannnot put in what isnt there in the first place.
For the settings to create a fresh VCD/SVCD I would tend to stick to the various preset templates built into VideoStudio.
heinz-oz
The VCD/SVCD standard is very particular about bit rates and frame sizes. You cannot change the template settings and expect your creation to play on a DVD player.
In my opinion, you are wasting your time. VCD quality is not the greatest to start with and, after two conversions will not be any better. Why do you want to convert to mpeg? VCD compression is mpeg1. I don't expect mpeg2 to be any better for editing and you will certainly not increase the quality of your video by doing what you are planning. On the contrary.
harry_hariz
already know
what do u mean by that?isn't the video i copy by right click and copy to hard disk is not an mpeg?how can i edit it now without coverting it from vcd to mpeg?in vs i look at its properties it shows that it is vcd pal but written mpeg1 there...can be the video direct convert to mpeg in vs?
i know mpeg1 is low quality...but i need to edit that things![]()
