My mpeg movie of a slide show has zero flicker. But the subtitles flicker on the TV screen.
Has anyone found a way of reducing the text flicker ?
DWS2 does not seem to have any project setting that might cure it.
Subtitle flicker
My MSP8 created PAL video is Framebased - this gives very clear "slide-show pictures" on my TV screen.
The English text was done in Notepad. In DWS2, the subtitles are in Arial (Arabic) font, size 24, colour yellow, and uses a black Background transparency of 66%.
The DVD project uses a Variable data rate of 4500.
The resultant text flicker seems to be caused by the TV's interleave action ( upper/lower field scans ). There is no problem when viewed on a computer screen.
Have you set your WS-2 settings to framebased, the same as your MSP one? You may have to go into Advanced MPEG settings to do this, if I remember correctly. If you don't have this feature, do a search here for Advance and you will find how to find the ini file that must be modified.
