Copying DVD's with MF4?
leprechaun
Post by leprechaun »
I am trying to copy a DVD i just made in MF4. Will MF4's disc to disc copy feature work if I have one DVD burner and one CD RW drive (doesn't read DVDs). I mean, aside from the DVD burner, does my other drive that i put the source to be copied have to be able to read DVDs?
MikeGunter
Re: Copying DVD's with MF4?
Post by MikeGunter »
leprechaun wrote:I am trying to copy a DVD i just made in MF4. Will MF4's disc to disc copy feature work if I have one DVD burner and one CD RW drive (doesn't read DVDs). I mean, aside from the DVD burner, does my other drive that i put the source to be copied have to be able to read DVDs?
I don't think I understand your question.
DVD's need to be read by DVD players, and DVD copies need to be made by DVD burners.
Mike
GeorgeW
CD-RW
Post by GeorgeW »
If you are asking whether you can put your source DVD±R/RW Disc in the CD-RW drive -- that will not work...
George
jcc
Post by jcc »
The process can be completed with a single DVD burner. You will be prompted when to change disks.
eswrite
Post by eswrite »
That's correct. I did this a couple of times when I burned directly to disk without creating folders and .ISO. I was able to copy from different disc formats, too: -R to +R, +RW and -RW. I don't like this, though. It's better/faster to create an image, then burn as many copies as you want.
