large files, need help.
herewearedr
Post by herewearedr »
i just recently got Ulead VS11+ and i've been working on a video presentation thats lasts around three and a half minutes. when i go to export it or share it as an mpeg or avi file i end up with some alarmingly large file - ranging between 200mb and 7gb.
can someone please help me to understand how to get it somewhere under 20mb without losing too much quality?
jparnold
motherboard: Gigabyte Z390 UD
ram: 16GB DDR3
Post by jparnold »
AVI files are approximately 1Gb per 5 minutes.
DVD (Mpeg2) files are around 1Gb per 15 minutes (depending on bitrate used) and good quality.
DVD rendered video should be playable on any PC.
John a
Just to slightly correct that, DV/AVI is about 1 GB per 5 minutes. Uncompressed AVI is about 1 GB per minute!! :!: :roll:
It depends on exactly what equipment will be involved in your presentation, but you burn it to CD as a VCD which uses smaller (but lower quality) mpeg-1 format. Or you could use one of the more highly compressed but high quality mpeg-4 formats like DivX (which will fit more than an hour of high quality video on to a CD). But anything you play it back on has to be rated to play a DivX disc.
Or you could use the Windows Media Format .wmf which is also highly compressed but good quality.
If you intended to play the video back over a projector connected to a computer, either of the latter two could be used direct from the computer.
But all this begs the question of why you are worrying about file size if it's a presentation of that length. Certainly you don't need something as large as 7GB, but I would not have thought 200 MB would be a worry as it would easily burn to CD and would hardly touch the sides of a DVD.
But is the presentation to be posted on the web?
