Hello, I've never ran into a problem like this before. I've always figured out problems by reading posts or doing a clean install of MSP. This one has me stumped.
When I attempt to place a Title in my timeline. I get the following message ..."An attempt was made to access an unnamed file past its end"
Iv'e reinstalled MSP 8 twice and still the problem exists.
Thank you for any comments on this problem.
MSP8 Titler module freezes
Welcome to the forums,
If you Google your Error message, it reveals numerous hits on this error, for several different applications. The only common thing I've read is that it is due to a corruption. About the only way to correct it is through a re-install. However if you have not already done so, try doing a complete un-install/re-install. Ulead programs leave a lot of files behind. So just doing a simple add/remove programs from the control panel and then re-installing may not correct some issues. Instructions can be found here : Re-installation of Ulead Products
Is it a specific title that causes this, or just any title? You could also try forcing MSP to rebuild the Title Library, to see if that may help. Go to C:\Documents and Settings\UserName\Application Data\Ulead Systems\MediaStudio Pro\8.0.
There should be a folder called Title. Rename it to something like TitleOld, just in case it does not work you can delete the one MSP creates, and rename it back. When you fire up MSP it will rebuild that folder and all the files contained in it.
desertpenguin
