Black screen on VS10+ when previewing project.
nomihs
Post by nomihs »
It's been a month since the last time I used VS10+ and it worked just fine then. Now when I go to either preview a video or still images in my timeline, or when I move the progress bar manually the preview window is black. I still have audio, but just a black screen where the video should be. I have tried recent video and stills I have imported into VS10 and also the stock images and video that came with the program when I installed it. The black screen isn't there when I am previewing just the clip, it only does it when I preview the project.
Any help with this matter would be appreciated. I would really like to get back to editing some footage.
Thanks,
Post by Black Lab »
Check File > Preferences and make sure the Instant Playback target is the Preview Window.
FRance
Post by FRance »
Usually the black screen but with audio would indicate that there is a problem with the codec. But if the movie clips are playing in your media player (video and audio) maybe the VS has the problem.
I have some things that you might want to consider:
1.Did you installed new video editing solutions/players/codecs? (they can cause conflict with VS sometimes)
2. Try Updating your video card driver and direct x version.
3. You can also check the ulead website for update patches for your software.
4. You can also try to make a clean re-installation of VS. Procedure can be found here:
http://www.explorecommerce.com/members/ ... 31&ID=9882
5. Oh and also what are the format of the images and video clips you are using?
Hope this would help. =)
nomihs
Thanks...
Post by nomihs »
Black Lab, that fixed my problem as far as I can see. THANKS A LOT!
I just did a quick check to see if it worked and sure enough, it did. Any more problems with VS anything, and I will come back.
Thanks again guys.
Post by Black Lab »
We'll be here. :wink:
