My biggest problem with MF is that it keeps trying to 'fix' MPEG streams that I know will play perfectly fine on all my computers & DVD players.
I'm ready to throw down my $50 for MF 6, if only you would fix this problem...
Goal:
To avoid unnecessary conversion times for 'valid' MPEG streams.
Source material:
NTSC Digital Video from a Motorola DCT6412 recorded via FireWire/1394 to a Windows XP system, using the tools described here:
http://www.avsforum.com/avs-vb/showthread.php?t=403695
Then, run through VideoReDo for editing and to fix audio timing.
Here is the file info from Video ReDo:
Final format is an MPEG2 file with the following parameters:
544x480,
29.97fps,
4:3 aspect ratio,
Bitrate: 9.0Mbps (Actual Bitrate: 5.67Mbps)
Here's what MF6 has to say about the clip:
And, here's the clip in question:
Warning: 106MB for a 2 minute clip!!
http://www.elfworks.com/temp/Henry_Rollins_Clip2.mpg
With MF5, I was able to massage the clips with DVDPatcher, and avoid the lengthy 'conversion' process - at the expense of motion menus.
With MF6, I just can't seem to get it to accept the clips without transcoding them.
I know you're trying to look out for the newbies, but maybe we could have an 'advanced' advanced mode for people who are willing to throw caution to the wind?
Thanks!
