Clicking on Auto Music crashes VS11
larikn
- motherboard: LENOVO Yoga2 31900058WIN
- processor: 2.60 gigahertz Intel Core i7-4510U
- ram: 2488 Megab
- Video Card: Intel R HD Graphics Family Display adapter
- sound_card: High Definition Audio Device
- Hard_Drive_Capacity: 512G
- Monitor/Display Make & Model: Lenovo
- Corel programs: Corel VideoStudio
I Have Vista, so upgraded to VS11Plus, have problems
I installed VS11 on my Vista after discovering that my VS8 did not work. I lost all my Auto Music though, and if I click on Auto music the program crashes, every time.!!
I did get two extra downloads but dont know where to install them too, could this be part of the problem ? There were no instructions that came with them. I have other problems as well but having a solution to this would be great.
larikn
- ram: 2488 Megab
Content Pack
Yes I did install the content pack but still have no AutoMusic. Im wondering if I need to select any specific location to install it too.
Is the content pack what contains the auto music. I uninstalled VS8 before starting, should I have done this ? first.
larikn
- ram: 2488 Megab
auto music crash
I have installed the Contents but still crashes when I select Auto Music.
If it was playing up in VS8, my inclination would be to go to Vista's Control Panel > Programs and Features and uninstall the two SmartSound files you will find there (SmartSound Common Data and Quicktracks). Then go to C:\ and manually remove the folder SmartSound Software if it is still there. Then go to C:\Program Data\SmartSound Software Inc, and manually remove that too. Then C:\Program Files\SmartSound Software, and remove anything that remains of that too.
If you feel brave enough, you might also want to contemplate a Registry search and destroy mission using Regedit to delete any references to SmartSound still in the Registry, but you might just be lucky if you are not brave enough for this. (I hope so anyway...)
Then reinstall VS11. This will ensure that the installation is completely fresh and not affected by any of the problematic files already installed with VS8. (You will note from the above that SmartSound installs quite separately from Video Studio...)
Good luck...!
Good luck...!
larikn
- ram: 2488 Megab
V11plus crashing
Ill give it a go but I had no problems with 8 in XP.....
You might not have, but I understood you to say that you installed VS8 on Vista and found that it did not work... The files it installed would not have been Vista compliant and they will still be there.
Please note I have amended my original post to give you the correct directions for Vista. The directions I gave originally were for XP.
larikn
- ram: 2488 Megab
auto music crash
OK thats looking a bit better, I appreciate your assistance.....
I uninstalled and deleted any references in the regedit then re installed quicktracks.
Now it does not crash but there are no tracks in the library
Any ideas
Any ideas
larikn
- ram: 2488 Megab
Auto Sound / quicktracks
Hi Ken,
Sorry to bother you but I need to get this thing working and I need it urgently. I would really appreciate a little more help.
The only Library that Auto Sound can find is the online samples when I choose all. There seems to be nothing else available and if I go searching for the libraries I can only find one which is 44k called
c:\program data\smartsound software Inc\......
encoding, or Exporters, or Libraries, or Previews, or Sound Files
in Libraries I have Comliled Libraries, Master Libraries or UserData all with sxl extentions.
I have tried unloading, reloading many times without any luck. Can you suggest anything at all ?
I remember having a similar problem with VS9. There was a problem with the SmartSound music. I finally managed to get it going, after several complete, clean, full, uinstall/reinstalls. It also involved a fix from SmartSound. There is a current patch for SmartSound, that is for Vista compatibility, and QuickTime 7.0. Download it HERE
There's some additional support information for SmartSound Quicktracks found here: http://www.smartsound.com/support/updat ... duct=ulead.
larikn
- ram: 2488 Megab
SmartSound Support
I have already downloaded and run this patch, is there are seperate one for quicktime, Ive heard this one mentioned a few times.
Should I perhaps get rid of all the references to Quicktime in the registry and try again ?
