Thumbnail Default Setting
David_S
- motherboard: Asus P5Q Pro
- processor: Intel Core TM 2 Quad CPU Q6600 2.4GHz
- ram: 4Gb
- Video Card: nVideo GeForce 8800 GTX
- Hard_Drive_Capacity: 4Tb
- Monitor/Display Make & Model: Philips 190B
When adjusting images the default thumbnail setting is 25. This is too coarse for most adjustments and I normally move the pointer to 6 or 12. Is there any way of changing the default so that the lower setting is retained next time I open PhotoExplorer. I am using PEx8.
2log
re: Thumbnail Default Setting
What thumbnail setting are you talking about. The only setting I know is the "Thumbnail Size". You can edit this from the "Preference". Press "F6" to go to the Preferences dialog box and go to the "Thumbnail Size" tab to change the thumbnail size.
