VideoStudio7 Audio level changes not effective on DVD
Laser3
Post by Laser3 »
I use VideoStudio7SE DVD and I have adjusted the audio level of some clips together with the audio levels of the added music track. These changed audio levels work fine when I preview the Project, but when I write the DVD using "Share", the finished DVD soundtrack levels are unchanged, i.e still at the levels at which the were captured.
Any ideas on how to fix this?[/b]
THoff
Post by THoff »
You probably haven't applied the V7.01 patch yet, it included fixes for problems with the audio mixer.
Download Page
Laser3
Post by Laser3 »
Thanks, will give that a try
Mark Powell
Post by Mark Powell »
Laser3, I had the same problem and was never able to fix with any patches or suggestions from Ulead. Have you had any luck? I find that if you follow the steps suggested in the information that be accessed via the link at the top of this forum board "read this first....." you can get around it. You can't go straight from editing to sharing and burning. You have to create a new project as per the instructions. Check it out.
