Ken Berry wrote:How big is the file? If you are aiming to burn it to a single layer DVD, the program should have no difficulty in handling a file around 4 GB in size. So there is no obvious reason to split it.
I have answered your question about cutting in another thread.
By the way, if you *are* intending to burn a DVD, then you should choose Share > Create Video File > DVD, and not mpeg-2 as the default mpeg-2 properties are not necessarily DVD compliant...
We also need to know what sort of video, and its properties, went into your project and what editing you did to it.
Here are the properties of the project:
The file size is 462.5KB
The duration is: 01:21:20:05
NTSC drop frame (29.97 fps)
MPEG files
24 bits, 720 x 480, 29.97 fps
Lower Field First
(DVD-NTSC), 4:3
LPCM Audio, 48000 Hz, Stereo
I only added a title to the project.
one sound track in the begining.
And a scene transition between each scene.
The project is composed of video and images. But the project gave me the error at the same spot each time way before I ever added anything to it. No transitions, title, or sound track.
