trevor andrew Thank You for your reply.
Did you capture to DV format via firewire cable?
Yes, I did capture with firewire
If you captured to any other format then you have to set the capture properties and the aspect ratio.
I did not set anything, just indicated 16:9 before editor has been opened.
If the DV-Mini tape has been used previously for 4:3 recording then recorded over at 16:9
I have never recorded 4:3, always 16:9
As I mentioned before, Windows Movie Maker (WMM) handle this very well. It imported 4:3 but in properties I had changed to 16:9 and it immediately switched to 16:9. Before burning I change to PAL or NTSC and it works, but this is WMM not VS.
By setting File-Preferences-Capture Tab-Set ¡¥Press OK to Capture¡¦
"Press OK for Capture" wasn`t checked, so I have changed
his pre-roles your tape allowing you to OK for capture.
Press Ok only when the preview screen shows 16:9 widescreen.
I don`t get it a little bit (sorry I`m not English native speaker)
Should I keep "Press OK to Capture¡¦" checked or it depends on something?
When I look at PROPERTIES on the screen it shows 16:9 MPEG, but it doesn`t shows this way. Is it possible to attach picture here, that I can show?
Thank You again for any help
