I have recorded a HDTV stream in native mpeg format. I can watch it in windows media player and winamp fine, but when I preview it in videostudio I get no audio. I have the full version of Videostudio 11 (upgrade from 8SE) and have installed AC3 filter.
AC3 details
Input format: AC3 - 48000
User format: PCM16 2/0 (stereo) 0
Output format: PCM16 Dolby Surround 48000
Decoding chain:
(AC3 - 48000) -> Decoder -> (Linear PCM Dolby Surround 48000) -> Processor -> (PCM16 Dolby Surround 48000) -> Dejitter -> (PCM16 Dolby Surround 48000)
Filters info (in order of processing):
Decoder:
Stream format: AC3 Dolby Surround 48000Hz
Bitstream type: byte stream
Frame size: 1536
Samples: 1536
Bitrate: 384kbps
SPDIF stream type: 0x1
Frame interval: 1536
Actual bitrate: 384kbps
AC3
speakers: Dolby Surround
sample rate: 48000Hz
bitrate: 384kbps
stream: 8 bit
frame size: 1536 bytes
nsamples: 1536
bsid: 8
clev: 0.0dB (1.0000)
slev: 0.0dB (1.0000)
dialnorm: -27dB
bandwidth: 20kHz/20kHz
Processor:
(Linear PCM Dolby Surround 48000) -> Input levels -> (Linear PCM Dolby Surround 48000) -> Mixer -> (Linear PCM Dolby Surround 48000) -> Bass redirection -> (Linear PCM Dolby Surround 48000) -> AGC -> (Linear PCM Dolby Surround 48000) -> Delay -> (Linear PCM Dolby Surround 48000) -> Output levels -> (Linear PCM Dolby Surround 48000) -> Linear->PCM converter -> (PCM16 Dolby Surround 48000)
No audio, full version VS11, AC3 filiter installed
formaldehyde
I have VS11+
The audio to the track isn't being recognised by VS, I got the details from winamp. VS just has the audio as "none". I thought that maybe there was some aspect of the audio stream that VS wasn't handling properly, so I installed AC filter based on recommendations in this forum for previous versions of VS.
