Error: either no video capture driver is installed in this
dswroan
Post by dswroan »
system or no device is connected.
i have a Panansonic sd3 HD - mem card AVCHD camcorder - trying to connect and transfer the video from the cam onto my pc
help!
jparnold
motherboard: Gigabyte Z390 UD
ram: 16GB DDR3
Post by jparnold »
You don't give many details but it seems that perhaps your PC does is not recognising your video camera. Did you receive (hardware) drivers (on CD) with the camera and if so did you install them? What version of windows do you have? Your video camera may be newer than your operating system and therefore Windows will not automatically install the driver for you.
Also check your 'hardware devices' via START > SETTINGS > CONTROL PANEL then double click on SYSTEM, select DEVICE MANAGER 'open' IMAGING DEVICES (click on the + sign next to Imaging Devices. Do you see your video camera (name) listed?
John a
dswroan
Drivers
Post by dswroan »
Thank you for your reply.
Well, ...hmmm. try this. I actually bought the SD3 panny from Japan- - the CD in the box that contains the drivers is in Japenese. my god.
so , i have been on the net trying desperately to locate the drivers for it- panny does not have them on the support page
jparnold
ram: 16GB DDR3
Post by jparnold »
I get the impression that your camera records to memory (not to tape or disk) - is that true? If so it should have a USB port and you should be able to copy any files tp PC via USB and go from there.
John a
etech6355
Post by etech6355 »
Search the VideoStudio & MovieFactory forums for AVCHD.
You should find many answers to your questions.
