Using Ulead Video Studio 7, I have been trying yo render an avi file to VCD.
The image is fine (better then pristine) however, when I try to play it on my DVD player (which is VCD capable) the sound drops out of sync by about 5 to 10 seconds.
Does anyone have any suggestions?
Thanks in advance.
Shelley
AVI to VCD Sound Sinc Problems
What are the properties of your "AVI" file? Where did it come from? Can you re-capture it in a less-compressed format?
An AVI file can contain video with any type of compression, and I'll bet it's a highly-compressed format. (i.e. People who use AVI/DivX report lots of trouble.)
You can try using a 3rd-party program such as SUPER (FREE!!!) to convert your files to VCD compatable MPEG-1 You can look at one of the Movie Factory Project-Templates to find the settings (resolution, framerate, bitrate, etc) for a VCD-compatible MPEG-1 file.
Your file probably has a small glitch (data corruption). (I call it "sneaky corruption" when a file plays OK, but causes trouble when you try to edit or convert it.)
For example, you may have a video frame with some invalid data. It might not even show-up when you play it back. If that bad video-frame is thrown-away during conversion but the associated audio remains, you will get a sync problem. (That's probably not exactly what's happening, its just an example of what could happen.)
P.S.
I assume you don't have a DVD burner. In case you are not aware, you can get a DVD burner for about the price of two music CDs! (Example: NewEgg.com). If you can afford the $30, if you have a desktop (not a laptop), and if you can install it (or if you know someone who can install it), it is well worth stepping-up to DVD. (But, that will NOT solve your sync problem.)
P.S.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
shelleybear
