UVS 8 problems adding chapters
JoEnezZ
Post by JoEnezZ »
I have compliant DVD-mpg2 files (full movies) encoded with tmpgenc 3.0
what I am trying to do is add chapter points then burn to DVD+R 4.7Gb with no menus.
I go into UVS 8, "share" "create Disc" format is set for DVD
"add file" "add/edit chapters" "auto" set for every 10 minutes
"ok" uncheck "create menus" box, then next.
the project tests ok & chapters function properly on built in player.
next I output to disc,
upon completion of the audio/video multiplexing stage
(a 15 to 20 minutes wait)
I get a 93006:1:0 error message
"some chapter entry frame numbers exceed the total frames"
then it halts the build process with no explaination or options to remedy this bogus problem.
I have tried removing some chapter pionts but it does not seem to make any difference.
, I end up getting pissed off at it , removing all the chapter points & burn with no chapters.
Does anyone have any ideas on how to correct this problem ?
my file size befor chapters is 4.0 Gigs, is this not enough room to add chapters without menus ?
Thanks,
Roger
MikeGunter
Post by MikeGunter »
I think there is a finite number of chapters one can havd - 99.
Can you produce the video without chapters?
Mike
beckmanear
Post by beckmanear »
