How do I get a Title that stays a while?
ruggy1
Post by ruggy1 »
I have VS7 and am trying to insert a text title with effects at the beginning of my project. I can get the title and the effects but cannot get them to persist for a few seconds before they disappear. As soon as the zoom (which takes a long time to actually Zoom) is finished my title disappears without having time to actually read it. Anyone know how to add a few seconds onto the end of a title? Thanks
MikeGunter
Post by MikeGunter »
Can you change view to Timeline and drag the edge of the title?
Mike
THoff
Post by THoff »
Are you saying the title disappears before the end of the specified title duration?
bobfrank
Post by bobfrank »
I'm using VS8 so I might not be giving you the exact names for the items in VS7, but I've used VS7 and I know the same options exist.
On the title tab near the Animation check box you should see a button to customize the animation attributes. Depending on which animation effect you've choosen, if you click on that you should see a drop down box to select the Pause length.
THoff
Post by THoff »
Ah, I apparently misunderstood. You want the title as it appears at the end of the animation sequence to remain on the screen.
I have previously done the following: I create two titles, one with the animation sequence, and a second one immediately following it in the timeline that is used for the static text. You can copy-and-paste the titles with all of their attributes, and then simply uncheck the Animation checkbox on the second title. You could even add a third one that fades out after the static title displays for a few seconds...
