Cannot burn a DVD
clives
Cannot burn a DVD
I have just purchased a Hauppauge WinTV15O PVR card that includes Ulead MF3. I can capture home video from a VCR and record in WinTV to an Mpeg file on the PC and it plays back ok. However when I try to burn the Mpeg to DVD using `Create VCD` option in MF3, or `Direct to Disk` option when capturing direct to DVD, I always get an error message as follows : `Cannot render streaming video 13011:5:3` that prevents me from burning the DVD. Can anyone help ?
htchien
Check http://www.ulead.com/tech/dmf/dmf.htm for update packs.
And contact Hauppauge for updated driver.
Hope this helps.
H.T.
Hope this helps.
H.T.
Ted (H.T.)
roryos
ive done the same thing clive and only way i got anything to burn was to uncheck the setting////// Do not convert compliant MPEG files!! wouldnt burn unless i did so i guess it did convert and it took about 3 hrs to burn 50 minutes of video and then i end up with a file in MF3 temp named convert and from what i understand direct to disc is not really direct or in real time !!!!!!!!!! someone tell me if im wrong or explain????????
