Setting duration for a batch of images - VS11?
ricwhite
Post by ricwhite »
Pardon my ignorance. I'm still learning this new software and I seem to be missing the obvious lately. Is there a way to assign the duration of images so when they are imported they will all have that duration? Or, if not, is there a way to select all images in the library or on the timeline and set them all at once rather than go through EACH image and set the duration? I have about 400 images I need to import and it would certainly save me a LOT of time if I didn't have to set the duration for each of them separately.
Thanks in advance for your help.
Post by Black Lab »
This is for v10 - v11 could be different:
To set it before capture go to File>Preferences>Edit Tab>Default Inserted Image Duration.
With the clips already in the timeline select the clips, then go to Clip>Change Image/Color Duration.
ricwhite
Post by ricwhite »
Thanks for your help.
